KLEIN 10-A/K10
Tema en 'Equipos' iniciado por arenas, 24/7/18.
    EN CAMINO,MUY BUENA OFERTA.
    K10-A
    $6,900.00
    • Superior Accuracy and Low-Light Performance
    • Long Range Aiming Lights
    • FFT Flickermeter
    • Comes with Klein Carrying Case, Tripod, Rubber Lens Hood, Cosine Diffuser, Extension Tube, Install Disc, and Certificate of Calibration
    AN INDUSTRY ICON
    The Klein K10-A has long been regarded as the industry standard in LCD calibration. It's enhanced optics give it a 3X advantage in sensitivity over the original K-10 SF. Known for it's superior speed, the K10-A can stream intensity data in 3.2 milliseconds and can provide color data in 125 milliseconds. The Klein K10-A is also extremely sensitive and color accurate. Large photo-diodes give the probe superior performance even in extremely low light (down to 0.00006 cd/m^2). Klein diodes are very large (5mm x 5mm each), thermally stable, and linear to report the highest degree of accuracy. The unparalleled speed and iconic design of this colorimeter have made it the most widely known Klein product.
    WINNING DESIGN
    Like all Klein colorimeters, the K10-A is ruggedly constructed with machined aluminum and high impact plastic. The K10-A’s auto ranging is solid state, and the housing is impact resistant to hold up to the 24 hours a day, 7 days a week usage that display manufacturers require. The K10-A’s compact size and light weight make transportation convenient. It is also fitted with a universal tripod mount for easy positioning and integration into workflows.
    EXCEPTIONALLY ACCURATE FILTERS[​IMG]
    For maximum accuracy, not only is the f1’ of Y critical, but the accuracy of X and Z as well. Each diode has specially layered absorption filters designed for maximum color accuracy. Klein colorimeters are also rigorously tested to ensure that each device is thermally stable with an operating temperature range of 15-35 C.
    FLICKER
    The Klein K10-A also functions as an FFT (Fast Fourier Transform) flicker meter. The probe measures and integrates Y data in the head, streams in real time to the PC, and then the FFT is performed. The Klein K10-A can measure regular flicker between 1-150Hz. Multiple methods for displaying flicker data including JEITA, VESA, and contrast methods are selectable in the software. The Klein K10-A can be used to analyze any luminance source, including the common refresh-rate flicker in monitors, and random flashes caused by the transmission of current variations through solid state devices (LEDs). All flicker information can be logged and reported with Klein Chromasurf.
    EN CRISTIANO:
    El Klein K10-A ha sido durante mucho tiempo considerado como el estándar de la industria en calibración LCD. Su óptica mejorada le da una ventaja de 3 veces en sensibilidad sobre la K-10 SF original. Conocido por su velocidad superior, el K10-A puede transmitir datos de intensidad en 3,2 milisegundos y puede proporcionar datos de color en 125 milisegundos. El Klein K10-A también es extremadamente sensible y de color preciso. Los grandes fotodiodos le dan a la sonda un rendimiento superior incluso con poca luz (hasta 0.00006 cd / m ^ 2). Los diodos Klein son muy grandes (5 mm x 5 mm cada uno), térmicamente estables y lineales para informar el mayor grado de precisión. La velocidad incomparable y el diseño icónico de este colorímetro lo han convertido en el producto Klein más conocido.
    DISEÑO:
    Al igual que todos los colorímetros Klein, el K10-A está fabricado de manera resistente con aluminio mecanizado y plástico de alto impacto. El rango automático del K10-A es sólido y la carcasa es resistente a los impactos hasta 24 horas al día, los 7 días de la semana que los fabricantes de pantallas requieren. El tamaño compacto y el peso liviano del K10-A hacen que el transporte sea conveniente. También está equipado con un soporte de trípode universal para facilitar el posicionamiento y la integración en los flujos de trabajo
    FILTROS EXCEPCIONALMENTE EXACTOS:
    Para una precisión máxima, no solo es f1 'de Y crítico, sino también la precisión de X y Z. Cada diodo tiene filtros de absorción con capas especiales diseñados para una precisión de color máxima. Los colorímetros de Klein también se prueban rigurosamente para garantizar que cada dispositivo sea térmicamente estable con un rango de temperatura de funcionamiento de 15-35 C.
    PARPADEO:
    El Klein K10-A también funciona como un medidor de parpadeo FFT (Fast Fourier Transform). La sonda mide e integra los datos Y en el cabezal, transmite en tiempo real a la PC y luego se realiza la FFT. El Klein K10-A puede medir el parpadeo regular entre 1-150Hz. Múltiples métodos para mostrar datos de parpadeo, incluidos JEITA, VESA y métodos de contraste, se pueden seleccionar en el software. El Klein K10-A se puede utilizar para analizar cualquier fuente de luminancia, incluido el parpadeo de frecuencia de actualización común en los monitores, y destellos aleatorios causados por la transmisión de variaciones de corriente a través de dispositivos de estado sólido (LED). Toda la información de parpadeo puede registrarse e informarse con Klein Chromasurf.
    Última edición: 24/7/18
    Mikamil, Stivy, RonaldDF y 2 otros les gusta esto.
  2. Stivy
    Stivy #YoMeQuedoEnCasa
    Cada vez el Lab...se va implementando con nueva tecnología, ahora sólo queda esperar los lado a lado, análisis, calibraciones, seteos, etc.
    Esperemos que las nuevas gamas nos den la satisfacción que esperamos y porsupuesto calibrarlo con el nuevo juguetito.
